gemcitypos
- Joined
- Sep 23, 2008
- 20
I am finishing up a 4.3 to 5.7 swap on a 94 Maxum with Alpha 1 Gen II.
The 5.7 engine is a '88 with same Thunderbolt IV ignition.
Everything seems to be working, engine starts, all gauges work, however when I turn the key (w/o starting) shouldn't I get a beep ... beep ... beep alarm after 7-14 seconds then go away after it starts? I tested the alarm like the manual says, jumping it to 12v and grd. It works.
Can someone push me in the right direction for trouble shooting? All the manual says is "problem with blu-tan wire" How do I test the various switches (oil,temp,lube) and where are they located.
Thanks again in advance.
