1986 evinrude 140 looper, started motor snd warmed it up. just before leaving dock heard a rattle for about 5 seconds. idle dropped about 100 rpms. drove ran the motor about 14 miles with the only differance being wot was 5400rpm opposed to 5800rpm before noise. check plugs 1 plug wet rest dark brown. I did a compression check and the wet cyl 10 psi, check cyl, no hole or scoring in cyl. Could this be a reed valve problem and how could the cyl have that low commpressionand still run at 5400 rpms. the moter pulsates about 100rpms when running at 4000-5400 rpms. sorry for the long post. confused
