I have asked multiple questions on this boat, finally found the main problem I guess. I should have checked compression a while back but I didn't. No compression in #3. All other cylinders are +\- 5 lbs. or so of 110 lbs. but nothing in #3. Odd part is that the boat cranks and runs good until you load it up. Just me planes out and runs same top end. Add a few people or try to tow a board takes forever to come out of the hole. Very weak. Sitting at idle no noticable miss. Has a strong smell of gas from the exhaust. Want some opinions, is this a full rebuild period or do I have some other options to check out first. I have not started anything yet. Was mad when I parked it and haven't wanted to look at her yet. Thanks
