no compression in one cylinder!!! trash engine or try to fix?
couger300
having some trouble so i decided to check compression. first plug i pulled had metal welded to it! that cylinder wouldnt even get a reading. i just bought this boat i cant believe this! the engine is a 95 johnson 90hp wondering what my next step should be. junk n look for a motor or try to fix? i really dont know.
BonairII
Re: no compression in one cylinder!!! trash engine or try to fix?
You've got to pull the heads to find out what's going on in there...plain and simple. If the motor is trashed(and you don't want to fix it)....part it out and recoup some of your money.
Solittle
And what was the compression before you paid for it?
couger300
honestly i didnt check it. i know i should have. i drove the boat and it seemed ok. i really knew nothing about outboards, compression, or boats in general. i did some research while i was looking but not enough i guess. this is one expensive lesson.
Tim Frank
Maybe, maybe not.
Could be something simple....and cheap.
Start with the head gasket....inspect the old one.
couger300
the metal on the plug is what scares me. you can see it in the cylinder through the plug hole as well
couger300
on a good note the other 3 were all at 110!
daselbee
If you have alum/metal on the tip of the plug, you have a real problem. Probably burned that piston up running lean.
I had one once that was like what you describe. Not only did it destroy the affected cyl (#1), but alum was all through the engine. Somehow it got all the way down to #6!!! There were aluminum balls all through the motor. Wipe your finger on the rod for #6, and come back looking like the Tin Man.
I fixed it tho, it was a full rebuild, probably cost approx $1500.
Pics:
couger300
this the best I can do! the shiny stuff looks to be metal. its on there pretty good i cant get any off!plug.jpg
couger300
daselbee, my goodness man! i dont feel so bad now! actually i do but that project would be way beyond my ability. it might be at the point though. what do i have to lose.
couger300
here are some pics of what ive found so far. its pretty scraped up n kind of pitted but enough to have 0 compression?cyl 002.jpg
daselbee
You can fix that pretty easily, it looks like to me anyway.
It is tricky tho. Not for the faint of heart.
couger300
well there really isnt much damage to the cyl wall!!! the majority of what is in that picture id aluminum melted on the wall. so im going to attempt to tear this bad boy down clean off all of the aluminum i can then have it honed. im hoping that will do it. if not the guy at the machine shop recommended a bore. so my next step is to get a manual. anyone know where i can get the best sevice manual?
