SteuryLover
- Joined
- Nov 19, 2008
- 191
Just got back from a ride today, after I took off from the harbor my power went down. After chugging around on what felt like 3 cylinders I pulled it out of the water and did a compression test. The top left cylinder has little to no compression. It will pump air when my hand is put up to it, but will not register on my compression gauge. So here is now my question. Where should I start to find the problem? What are the different issues that would cause this problem. I do notice that there is some what looks to be calcium around the head gasket. I let a buddy use the boat a few weeks ago. He left it in the salt water and used it for 5 days before flushing. Would this cause the problem. Thanks in advance for everyone's help on this.
