vanceboroguy
- Joined
- Aug 12, 2008
- 10
I have a 1978 Evinrude that has virtually no compression on one cylinder ,the other five have 125lbs.The cylinder with no compression will build up to 60lbs.What can I expect to find wrong? How long will motor hold together like this? I noticed the last three times we skied it was not as strong out of hole and idled not as well as it had. Motor is old but was never used much.Will cylinder receive enough oil this way or will it seize? The boat will still go around 39mph,but used to run in the 40s.
