no fire on # 2 and 4 cylinder 50 hp mercury
dridog
I have no fire on # 3 and 4 cylinder.How do tell if it is coil or control box, or Stator?
dridog
Re: no fire on # 3 and 4 cylinder 50 hp mercury
Im sorry its # 3 and 4 cylinder.
Faztbullet
Well you can rule out the trigger as 1 & 3 are a pair and 2 & 4 are a pair. You can swap a green lead from a firing coil to a none firing position on switchbox to see if coil/s has failed. Switchbox is highly suspect for your problem with grounds on ignition plate or coil mounting that may have blown it....
