No Fire Situation.
MTboatguy
1973 50 HP Evinrude lark, ran fine in the fall before I covered and put to bed for the winter, now it seems it has a no fire situation on either cylinder, just checked with spark tester, both one with a light and one with a gap test. Last fall had to rebuild the neutral safety switch and like I said, it ran good before putting it away and has not moved until last weekend when I pulled out of storage.
So with a no fire situation, is there a good trouble shooting sequence to start checking which component is the problem.
Thanks for any help offered.
gm280
Boat gremlins are always worst then vehicle gremlins... Make sure you don't have the kill switch in the wrong position for starters. Then go from there.
