I have an '87 Wellcraft with Mercruiser 3.0 with Alpha I outdrive, and I recently had to replace numerous parts in the upper unit and gimbal housing. I also replaced the lower unit water pump as well, along with the lower shift cable. Outdrive was installed according to service manual, and I thought all was ok. For the first time I fired it up today. I noticed right away that it wouldn't shift into forward, only reverse, and after in reverse I wasn't able to put it into neutral. I did the 'put the shift cable all the way forward, and turn the prop clockwise' thing, and the prop locked into place. When I put the cable all the back and turned the prop CCW it didn't lock, but I heard a metallic pinging sound from inside the lower unit as the prop turned. This was with the lower shift cable disconnected from the upper linkage and doing it by hand. Shift cable slid back and forth with no issue whatsoever.
Did I miss a step when reassembling everything, or is something wrong with the lower unit? It seemed to work fine before everything was taken apart last year....Thanks.
