No Forward No Reverse
Hello I have a 1985 3.0 140Hp merc with a alpha drive.<br />Just replaced impellar and put back together. Now when I go into reverse or forward the motor dies.<br />I installed the lower unit the correct way(put it in forward at the throttle and forward at the shifter in the lower unit) twice and still same problem. I had REV and FWD before I droped the lower unit, any suggestions?<br />Adjust the cable?<br />By the way Prop locks 1 way in rev and dosent lock in fwd, but was locked when in FWD when I installed the lower unti. Please Help
Haut Medoc
Re: No Forward No Reverse
I think you may have not gotten the upper shift shaft aligned properly. It should face directly foreward.........
Ayuh,.............<br /><br />I Think you Missed when you slid the lower unit back up into the upper unit..........
ok so I reinstalled the lower unit and adjusted the shift cables so I have reverse and forward gears, also measerued cables at the correct places all ok.<br />So When I start it and put it in gear it dies in both forward and reverse, could this be the shift switch or are the adjustments really touchy? I dont think I need a new shift cable due to having rev and fwd before I dropped the lower unit. Also this is the second time I changed the impellar and never had this problem before?????
Haut Medoc
But does it shift hard? If it does it is the shift cable hanging up the interupter switch, and the cable probably needs to be replaced.
Haut Medoc
Usually when you do a direct replacement, ie. pull the drive to do maintenence - you should not have to adjust the cable and YES the adjustments are very touchy.
