No forward, reverse dies huh??
paintman_15
I have a 1980 marquis riviera with a 140hp mercruiser.<br />model mcm 140<br />motor serial 5707378<br />mercrusier serial 5697702<br />stern drive serial 5655248<br />181 displacement<br />Saturday after backing up, the boat would not disengage and go forward.<br />Shortly thereafter the boat would not go forward and dies when you try to go<br />backwards. When I give it gas and try to go forward it just acts as if it<br />is in neutral. I am trying to find out the most likely problems here. Any<br />assistance will be greatly appreciated. This is the first boat I have owned and am pretty much an idiot with this, but did some looking and discovered that when I put it in reverse the shift cable moves a piece which pushes a switch and the boat dies. When I move it forward a the switch is not avtivated. Any Ideas before I destroy this boat by taking it apart myself? :confused:
Re: No forward, reverse dies huh??
Classic Symptoms of a Frozen/Broken/NFG Lower Shift Cable..........<br /><br />Replace it,<br />And,<br />Your Problems will Go Away..........
paintman_15
Does anyone have a good parts breakdown picture? The one I find are not so good. Thanks
paintman_15
Is this lower shift cable the part physically attached to the shifter?
paintman_15
Another uniformed (stupid) question. Due to the limited room does the sterndrive have to come off to do the lower cable replacement?
qystan
Not mentioned, is this an alpha drive? If yes, drive has to come off. <br /><br />Not difficult. Mercstuff.com has a description. Note that it is heavy and wise to get help to avoid back injuries.
paintman_15
I got the drive off and am on the hunt for a cable before this weekend if not will order online. Thanks for all the help guys.
