Yes the engine will crank all day...but not start. I have spark and timing is good.
I've recently installed an petronix electronic ingnition and did not have spark until I took the metal lining out of the rotor (long time to figure this out and not sure what that metal did, except it prevented me from getting any spark). Both engines have the same problem. Anyway, spark and timing are good now. Gas to carb good. I poured gas into carb and got some sputtering...then back to just crank and no start. Seems like it want to start, seems fuel starved and sounds like it needs more power to start it up.
Having 12V on both sides of the coil is fine. The negative side of the coil goes to the ignition module and tachometer. What is the metal contact and tab you keep mentioning, and do you have a pic?
http://www.boatfix.com/merc/Servmanl/16/16F4R2.PDF
The metal contact that is inside the rotor...that sits onto the dist shaft.
Ayuh,.... Is it Good gas,..??
If the carb were squirtin' gas in, it's gotta start,...
Yer dumpin' gas down the carb proves that,...
something's up with the carb, or the fuel, or the delivery of it,...
Not sure how we know timing is correct if they won't run? Twist the disty clockwise a bit and try it again.
Thanks AllDodge. I started another thread about my rotor and discovered I switched the starters on my engines when I put them back in the boat. I am hopeful that I am on the road to a start...real soon. Thanks again.The metal inside the rotor is for spring tension so the rotor doesn't move when installed. As you say they can come with and without the spring tension piece, but these pieces have no contact with the electrical distribution of spark. All mercruiser distributors rotate clockwise when looking down from the top of the distributor. If your distributor is going counter clockwise this is incorrect.
Firing order is 1-8-4-3-6-5-7-2
What's real weird is if it was firing on the wrong cylinder you should be getting some back fire or preignition firing. For it to crank and not hit has to still be fuel.
I am still having trouble understanding how timing was set to 8 degrees btdc with a timing light when they were not starting, especially when the engines were turning backwards. Good luck on this![]()
