I'm working on 68 Johnson 85 HP.
Model #V4AL-20A
Serial # J2904731
I did some ignition work on this motor (messed with the timing also) after I got through working on it I took it to the lake and tried to start it. It tried to fire then acted like it was out of fuel. I squirted some fuel into the carb and it started and ran until it burned the fuel that I squirted into the carb then died.
I took it home and pulled the fuel line at the carb, cranked it over and got no fuel. I changed the fuel pump tried the same test and got the same results.
Questions:
1. Could it have something to do with the ignition timing?
2. How do I check the timing with the engine not running?
3. If not in the timing what else can I look for?
I'm new at working on boats, but I've worked on a few cars.
Thanks.
Model #V4AL-20A
Serial # J2904731
Questions:
Thanks.
