man-of-war
- Joined
- Apr 23, 2004
- 175
HI ALL,<br />I had the boat out on the lake this weekend to start the break-in procedure. The fuel pressure was 6 psi when I launched it on Saturday. I ran the engine for 10 minutes then the pressure dropped to 5.5 psi. That's fine. I started the engine today for another run, the pressure was bouncing from 6 to 5.5 psi. I ran the engine for an hour between 2500 to 3000 rpm then I switched off the engine for about 3 minutes and then started it again. The pressure was now at 2.5 to 3 psi. I didn't like the look of that, so I bought the boat home to try to rectify the problem. I hooked it up to the garden hose and started it up. It read 0 psi. I tried shaking the gauge, no luck. I replaced the fuel line from the gas tank to the fuel/water separator, swapped fuel pumps, got the needle to 3 psi and removed the gauge. Then I applied compressed air and the needle moves. I bypassed the fuel/water separator direct from tank to fuel pump and still got a reading of 2.5 to 3 psi. The needle pulses. I installed a fuel filter between the carb and the fuel pump and the gas does not fill the filter - just about 1 cm full (I can tell that by holding the filter vertically)......HELP
