no gas top cylinder 73 Mercury 650
mwbaughan
Re: no gas top cylinder 73 Mercury 650
also, the trottle arm is opening the plates but not advancing the distributor, i opened up the arm and thought i put the spring in right - but maybe not since it is not pushing the distributor arm forward :confused:
joblo33
What was the reason for rebuilding the carbs? Does this problem predate carb work or is it only since doing the rebuilds?<br />Eric
mwbaughan
I rebuilt the carbs becuase of the same symptoms mentioned earlier (little to no fuel to top cylinder).<br />It is getting plenty of gas to both carbs - good fuel pressure - but not evenly distributing fuel in the crankcase. I checked compression and all are 120-127 psi - the lowest being that top cylinder. I suspect stuck reeds but have never worked on these. I just ordered two sets off ebay. The spring must be sprung in my throttle lever - I recently set the motor up in the boat while I replaced the transom without unhooking the linkage - perhaps this sprung it somehow.
joblo33
Ya, sounds like reeds to me. You can see them through the hole when you remove the carb. You need to pull the powerhead and remove the crank to access them. You might be able to clean them up through the hole behind the carb. I haven't tried because I always have the powerhead off for other reasons when I see the reeds.<br />Eric
