I have a 63 75hr speedy 4. JOHSON Just bought it and did a tune up. Every thing is set perfect for the timing and the synchronization. The motor start worm or cold on 4 revolotion (right now)
But out on the water when you go full throttle it takes awile to build up speed. Once at top speed i'm only going 22 mil.hr. and the motor has a odd sound not a knock ing sound more like a ticking or a wa wa wa wa sound . Just has no power. what should the compreshion be on the cylinders. someone told me the reeds may be bad is this true??? As i had said befoe it starts great quick on the thottel untill there is a load on it then it take awile to build up speed it's pushing a 16-ft glass boat........ any ideas out there
I also have a post down below with no reply's about a 77 25 hr johson with ignition problem any reply is better then none. even if it to tell me to by a new motor. All i now is the fish are getting AWAY !!!!!!!!!!!!!
