alandchris
- Joined
- Dec 25, 2007
- 106
Last chance for me before having to bring it in to the marine repair place...
If you know wiring, can you please help.
My electric start motor does not start - only if I put jumper cables from the battery directly to the power head ground and to the the starter selenoid.
The old motor was a 02 Merc 25 HP electric start 4 stroke. The new motor (with the problem) is a n 04 Merc 9.9 electric start. Note that the previous motor on this boat had tilt / trim and this new motor does not.
I opened the whole side of the boat up to trace the wires.
All wires coming INTO the fuse panel work perfect - all have juice Red and Black show a good test on the meter.
Here's what I see - 3 areas of evidence with "missing connectors".
Evidence 1
I have a red wire with a white stripe and black wire coming from the fuse panel on a 20 amp fuse - not connected to anything. A meter test shows juice coming thru these wires.
Evidence 2
I have a blue wire with a white stripe and black wire coming from the fuse panel - I believe it's on a 5 amp fuse - not connected to anything. A meter test shows juice coming thru these wires.
Evidence 3
I have a white plastic three way connector (female side only) where there are 6 wires - 2 red with white stripe, 2 blue with white stripe and 2 green with white stripe. Each of these same color wires are hooked together and occupy the same connector "pin" (ie 1 of 3). In other words, both red/wht on 1, both green/wht on another, both blue/white on the last. This connector has 1 set of the 3 different colors going into the control box ( I believe these feed the tilt / trim switch)... On the other side of the coin, the green/white and the blue/white go thru the boat cable down to the motor for the trim ( and are dangling by the plug since I don't have trim).
The red/white stripe on the other hand goes to the ignition switch "B" battery lug and is spliced via a connector to also go thru the boat cable to the motor - so this red/white wire goes to both the "B" ignition lug and into the motor. There is not other red type wire feeding into the ignition switch.
So I guess my question is - where am I supposed to get the power to feed the motor / ignition. Is it possible that there is a missing male side connector that would take the "Evidence 1 red/white stripe wire into the red/white side of the female connector that would then make the trim switch hot - but also feed down the the boat cable into the motor to make the starter hot ? If so then what about "Evidence 1's Black ground wire" where would that go. Does the blue/white, green/white need any hookup.
To test my theory, I jumped the Evidence 1 red/white wire to the red/white wire on the missing female connector - turned the key and it seems like I'm getting at least 1/2 juice to the starter - it turns the starter - but not enough to start the motor. (The batteries are good) Am I missing something here ?
Attached is a pic.
Al
Evidence 1
Evidence 2
Evidence 3
Attached is a pic.
Al
