The engine is in a 1993 SeaRay. Its a 1993 4.3L Mercruiser w/ a Thunderbolt IV Ignition system. I'm getting no spark when I ground the wire from the coil to the distributor. I have 12V at the coil, the manual says replace the coil or the Ignition Control Module. That sounds too easy, does it sound right to you. BTW, What does a coil or ICM run? Thanks in advance for the replies.
