I have a Volvo Penta V6-225-A in a Regal 2013 boat. One day fine, next day turn key, everything powers up as normal, no response from starter. So checked starter, good, checked power from key ignition, good. Checked starter relay switch, good. Checked power to relay when key is in start position (turned right), good.
So from the Ignition relay to the starter solenoid the connection is not there and no power is sent. So is there a fuse in between the two points, or something that could break the connection. Attached is the top view of the motor. I am looking for the next thing to check.
Any advice would be great.
