88 GM 3.0 Mercruiser, 4 banger, Merc Carb, Breakerless Ign Upgrade
OK, Last time started was 10 days ago. No problem. Today turn the key and nothing, well almost nothing. I suspected low battery and/or connection issues. I checked fluid levels cleaned and charged the battery, put in needed new battery cables - both, and cleaned all other connections that I could find and replaced the other solenoid that is not part of the starter. I get all the signs of low battery, barely a couple of clicks from the solenioid more of a mild buzz, same on tilt solenoid. I checked the battery and get 12.45 V when off, 8.5 volts with ignition on. Huh? Yes power shows up at the starter solenoid. This isn't rocket science, what am I missing?
