I was drilling a few holes in my floor to try an locate a leak (Trickle leak --about 1 gal/hr) on 1988 Bayliner 24'. When I cut a hole in the cabin floor, I was a little shock to see daylight in the otherwise darkened cavity. The daylight was coming in about a 1" wide strip in the keel (very center line of the boat bottom). Shinning a flashlight in the hole, and then looking under the boat I could see an amber glow, coming out of the keel for a length of about 6' under the cabin area. (There is not bottom paint on the keel area in this section, due to wear and outside surface looks porous.<br /><br />Is this normal. The keel section looks to be just glassed in. It does not look to be very thick either. I am concerned, that beaching the boat or even trailer loading/unloading, could damage this thin keel area.<br /><br />Also has anyone heard of or used "KeelShield"? It is a strip of rubber or something that is 7' long and 5" wide that attached to your keel to protect it. I was thinking that if this was installed with the inlcuded #M VHB adhesive, that it would also serve to prevent any leaking that may be resulting from the porous surface of the keel and also protect that thin membrane.<br /><br />Any thoughts<br />Thanks<br /><br />day<br />thick blocking glassed to the hull in the keel area(no actual keel wood),
