Blu Lunch;
Don't use starboard, if you are serious, as starboard is extremely heavy, doesn't carry weight well without support (you would have to increase stringers or inject foam), doesn't take adhesives well and would be VERY expensive for your intended use. Not to mention UV damage, slipperiness, dirt retention and stains.
If you, or anyone else, wants to replace a deck, w/o wood, look into the new composites that are available.
I have used diab and honeycomb composites. They are actually cheaper, do not absorb water, can be worked with a knife, and are lighter than marine grade wood.
4'x8'x3/4" DIAB can be less than a $100 and can weigh less than 10lbs.
4'x8'x3/4" honeycomb can be less than $90.00, and weighs frrom 4 to 5lbs.
You do have to treat it different than wood when forming attachment points for fittings or screwed in add-ons, but it will not rot.
Fiberglass is applied to both sides equally to form a sandwich, which is then cut and installed in you boat. Leaving the underneath side uncoated is not an option, and shouldn't be on a wood deck either.
I use Fiberglass Coatings for my supplies,
www.fgci.com, but there are many other outlets around the country that carry the stuff.
I even used a super compressed foam for the transom of a boat I repaired that is the same as manufacturers are using today. This stuff was HEAVY, but had to be to hold the weight of the engines.
Bob
