rowdyredneck
- Joined
- Dec 12, 2007
- 17
I just finished putting the water pump together in my '96 60 horse Mercury two stroke. I followed the directions in the service manual by placing the shifter in forward gear before removing the lower unit. After replacing the impeller and gaskets, I carefully slid the lower unit back into place making sure the splines on the shafts lined up. Now it seems to be stuck in gear...regardless of where I place the shifter I can't freewheel the prop. If I turn the prop counterclockwise (facing the prop) it will turn the engine over, and if I turn it clockwise it ratchets. What did I do wrong and how do I fix it?
One other thing, when I replaced the impeller, which way do the blades curve? The way I assembled it is with the blades folded back as if the impeller is turning clockwise when viewing it from the top. I lubricated the blades and housing with dishwashing soap and it slid together easily, just not sure if they are pointing the right direction or if it even matters.
