No Oil Alarm Occurrences on Rebuilt 1986 Johnson 150 J150TXCDC
Terrapin
VRO No Oil Alarm Occurrences after VRO preventive maintenance rebuild with OMC/BRP Air Motor and Gas Diaphragm rebuild kits.
  • No previous problems with VRO (4 wire) since it was installed in 2008.
  • The No Oil Alarm occurred randomly four times over 60 gallons of fuel burn.
  • Occurs shortly after (max of 2 minutes after) running at WOT for a period of time (WOT time varied from 2 to 6 minutes)
  • I can’t replicate the problem when I try
  • When it occured, I imediately throttle down and it stops. I may hear no more than 4 quick beeps at one second intervals when it occurs.
  • Checking the oil line primer bulb, I always find it hard
What Changed:
  • I rebuilt the VRO with OMC rebuild kits in August as a preventive maintenance with powerhead rebuild
  • Did not replace air vacuum O-ring between VRO housing halves, because one didn't come with the kits. (could that be the problem?)
  • No other changes other than I rebuilt the engine and have also been running premix in tank. I am still running 100:1 premix in gas tank.
  • Prior to using rebuilt engine and VRO, I did drain the oil tank (turned it upside down) to check for water and refilled with new XD50 for break in (did I introduce a few air bubbles?). New oil tank and hose installed in 2003.
  • Using proper OMC ratchet snap clamps on all oil and gas hoses.
  • I have always used Champion UL77V plugs (could they all of a sudden be introducing ignition noise since they are not QUL77V ? )
  • The VRO oil pump seems to be pumping fine and oiling at a 50:1 to 70:1 mixture rate to the best of my monitoring. I understand the VRO oiling rate is said to vary from 50:1 at WOT to 150:1 at idle.
What could be causing this alarm condition that I can’t replicate? It scares the hec out of me and I don’t want to continue running premix in the gas tank.
Should I replace the pump with a new VRO pump?
Faztbullet
Check the float in oil tank and screen. If ok replace the pump as cannot rebuild oil side. The side you repaired is fuel and air motor and if o-ring was problem you would have fuel delivery problems. Only use OEM pump and not knockoff chinezem brand.
Terrapin
Very good point that I should have thought of prior to rebuilding the air motor and fuel diaphragm. I should have just replaced the the VRO since it is 13 years old and I was rebuilding the powerhead. I just ordered a new OEM VRO from "Leader's RPM".
Faztbullet, as always, thanks for your reply !
