I have a 1996 Evinrude e90tleda with the VRO still hooked up. My "NO OIL" light has been coming on intermittently but with a continuous tone (same one as an overheat). This has happened at idle and WOT. I have tested the temp sensors by grounding them to the block and the light indicating overheat comes on. This first happened after I had changed the inline filter and water separator leading me to believe it was caused by air in the lines. Since then I have looked for air leaks and replaced hoses and the primer bulb but it still happens. I tried running it on a test tank with premix and disconnecting the oil line to the VRO for about 5 minutes and never got an alarm. Is there a way to test the "NO OIL" and "LOW OIL" alarms by grounding them out? My horn does the self test when I turn the key. Any ideas on what would cause these problems would be appeciated.
