crazy charlie
- Joined
- May 22, 2003
- 5,602
I am having this looked at this week but would like to know where the actual problem is.Dual mercruiser 230 i/os,alpha drives 1988. Dual shifter controls are making a condition that mimic when the shifter is not in neutral and you attempt to turn the ignition and you get absolutely nothing at the key until you move the shifter into neutral.Since I have been able to get the motors started ONLY after jiggling the shift lever until it is in the perfect position.It has gotten worse in the 1 week since I first noticed it.Is there an actual switch inside the shift controls that disengage the ignition switch at the key??? The controls are not Quicksilver style.I assume they are aftermarket.Instead of puching a side button to rev out of gear,my shift lever gets pulled away from the body of the shift mechanism to rev.Still trying to post a pic of it.I am just very curious where the actual cutoff is??? Charlie
