no power at wot
1988 175 evinrude....runs great at idle..... at wot motor needs more fuel...i can push the choke and feel the fuel working... carbs are clean....any ideas?
bktheking
Re: no power at wot
Have you tried squeezing the bulb at WOT, maybe a weak fuel pump.
Lines might be blocked, has it got a fuel filter as well?
Re: no power at wot
yes, tried the bulb ....yes, to fuel filter, carbs adjusted.......almost feels like a vacum problem....going to try starting fluid test tomorrow around gaskets
bktheking
Re: no power at wot
Maybe a vacuum leak but typically it doesn't just happen when you open it up, it would run like a dog at idle. Idle would be lower if vacuum were an issue.Have had the carbs out and put a kit in them?
bktheking
Re: no power at wot
You said carbs are clean. Carbs are clean when they are cleaned and a new kit put in.
Re: no power at wot
i'm gonna clean the carbs. I am also going to check for air in the line, If there was air in the line, would't all speeds be effected?
