I bought the motor from my favourite shop ( The Dump )
for fifty bucks.
The 45Hp Chrysler had almost no corrosion and the paint was bright and shiny.
Ran it in the tank, it started easily, had a good idle, pumped
lots of water.
Would start and run on either cylinder.
Put it on the boat, went for a drive, there was no power
couldn't get on the plane.
Checked the compression 60PSI both cylinders.
Took the head off, no holes, no corrosion.
Took the exhaust cover off, no corrosion the rings free to move in their slots.
On a car with lots of miles on the clock there is usually a
10-15thou ring at the top of the piston travel, the O/B had
no such ring.
QUESTION
Will a set of new rings bring the compression back?
for fifty bucks.
lots of water.
no such ring.
QUESTION
