I have a 1998 250 saltwater series, and the auto oil system failed last week. I think I may have caught it in time because after manually mixing the gas it seemed to be running fine. A few hours after that happened it was running along at full throttle when it lost all power. After that for a while it would only run at about one third throttle, any more than that and it would run jerky almost as if it were running out of gas. Now at times it seems to run fine at full throttle then it will go back to running jerky and unable to open it up. Any ideas if this is a result of the oil failure or just something else. thank you
