No power on '92 90 hp Evinrude
chillybilly
I have no power on my motor, 1992 90 hp Evinrude. The moter began running rough about 200 yds from the lift, thank goodness. The tach was bouncing to zero then to what I would guess was the correct RPM. Then all the power through the ignition died. Tilt wouldn't work to raise the motor, turn on the key and it doesn't whistle, gauges don't come on. Had to manually release the tilt to raise the motor for transport home. Any ideas?<br /><br />Thanks, <br /><br />Bill
JB
Re: No power on '92 90 hp Evinrude
Most likely a broke/loose/corroded connection in the wiring, chillybilly.<br /><br />Good luck. :)
