No Power on Ignition Switch Merc 260 1984
HPLou
1984 Mercruiser 260 5.7L S/N 6846787
I had never had problem before and last week end I tried to start my engine with no luck.
When I turn the key, nothing happens; No Click on the starter, the guages does not have power doesn't move.
I checked the Ighition Switch Fuse and it is not blowed. I have no voltage at the Batt Wire on the Ighition Switch.
My Quick Silver Control is on Neutral Position (knob pressed).
I need some help with my problem.
Thanks
Louis
Re: No Power on Ignition Switch Merc 260 1984
Thanks
Louis
Ayuh,... There's a 50amp breaker On yer motor, that probably needs to be reset...
'course, then ya gotta find the short that tripped it...
HPLou
Thanks Bond'O for your quick reply.
There is a Red Button on the motor,
Is it the one youre taking about? (sorry no photos)
I can not press to reset. Seems to be jammed.
Louis
Louis
Ayuh,... That's it,... Get yer Testlight, 'n follow the Power...
That's just my 1st Guess,...
If it don't push in, maybe it ain't the problem... a Testlight will tell ya...
HPLou
Thanks Bond-O
I will get back in aa day or two.
Don S
When you test the circuit breaker with the test light or a volt meter, make sure you check both terminals. It wouldn't be the first breaker to fail for no reason in the marine environment on a hot engine that probably gets wet with condensation.
Might also check to see if you have a 15 or 20A fuse under the dash near the ignition switch in the red/purple wire.
HPLou
I checked the 20A fuse under the dash near the ignition switch and it's OK
The connector from the 12V panel that supplies electricity to the fuse was defective.
I replaced it and all is working now.
Thank You All for your help.
