RickeyD07
- Joined
- Mar 5, 2022
- 9
I own an 06 Azure DB powered by a 2015 I/O 5.7 350 MPI Mericruiser engine..... Recently purchased and I changed out the dash with all new switches and ignition. New blower motor. Went to warm the engine for an oil change, nothing...all accessories work but no power at ignition. I've changed the 90amp fuse at the starter, checked the 50amp on top of the engine, replaced the 20amp running along the bulkhead behind the motor. There is 12.7amps on the red wire to the 90amp starter-fuse and 12.7 on the wires from the 90amp fuse but no power to the smaller yellow-red wire connected to the starter even when key is turned to start. Tracing the yellow-red wire there is an attach point on top of the motor immediately forward the red 50amp reset circuit breaker (please see photo)...I noticed the object has two-terminals: one terminal receives a blue-red (purple) wire that is hot (12.7amps) and the other terminal receives the yellow-red wire which is not hot...even when I turn the ignition to start. This object also receives a black ground wire.
Is the yellow-red wire at this junction supposed to be hot? Could this be the culprit not allowing power to the switch or the starter? Does anyone know what the object is called so I can replace if warranted? Thank you, Rick
