No Power to lights, bilge pump, live well and running lights
jddlg8
Hello, I just bought a 1988 393v comanche ranger boat and the engine runs and the trolling motor works but I have no power at the console at all and no lights nothing works. Can somebody help me please...Thanks in advance...
stormy weathers
Re: No Power to lights, bilge pump, live well and running lights
check your fuse panel. Turn on your bilge pump and start to tap your fuse panel breaker panel. if that dosnot work test the main fuse to the panel and wor then the fuse on the panel. As old as the boat is it will be moisture on the panel.
jddlg8
Thank you Stormy Weathers, I'll give it a try..:)
jddlg8
I called Ranger and they fixed my problem. he he he I had to wires on the wrong battery post. Live and learn...:D
