ggundersen3
- Joined
- Dec 25, 2007
- 249
I bought a new Kenwood marine stereo receiver for my '95 Four Winns Horizon 190 as the old one was not working at all since I bought the boat last year. After making sure speakers were wired correctly, I began to connect power to the receiver, found a good ground and connected it(black wire/negative) securely and then found several available 10 amp fused circuits on the fuse box/block that are hot(live) all the time(battery) and connected the (yellow) wire(positive) securely. I have no power to the unit. There is a 3rd power wire (red) from the unit to connect to the ignition. Where do I connect that? There is no circuit on the fuse block that turns on and off with the ignition key as I tested them and they all appear hot /live all the time(running off the battery). Is this why I have no power? Why is there 2 positive wires from the unit? Yellow wire marked "battery" and red wire marked "ignition" Does that red wire have to be connected to the ignition (if so where do I connect it?)or could it be connected to another 10 amp available circuit on the fuse block that's hot all the time even when ignition key is off. Explain please. Much appreciated. Maybe i'm complicating this but tell me is it possible that the red and black wires are the "real" positive and negative wires to operate the unit and that yellow is simply connected to the battery for the units clock and station preset memory. Again clarification is much appreciated here.
