no power to the prop? volvo penta 350
abearroyo76
i took out my Bayliner ciera and it drove fine for about an hour. i parked it and then ran it agian that afternoon and when i made a u turn and when i got on the throttle everything was fine until the boat started to slow all of a sudden. rpms were finr just wouldnt move anymore. spun prop? where do i start
Re: no power to the prop? volvo penta 350
Ayuh,... Welcome Aboard,....
Scribe a line across the prop, 'n Try it....
The Volvo guys are gonna need yer Full Model, 'n serial #s to get much deeper...
abearroyo76
sorry what does "scribe a line mean" working on getting the rest of the info. thaanks
Don S
oh itss a 1986 volvo penta omc 350 v8 275
Time to post some pictures, in 1986 there was no such thing as a Volvo Penta / OMC. You may have an OMC stringer drive, or an OMC Cobra drive, or a Volvo drive. All would have different probems, but someone may have put in a Volvo motor. They All used Chevy 350 engines.
Don S
The Volvo drives have a cone clutch that can slip. Have you checked to see if the gear oil is milky? (aka water in the oil)
abearroyo76
No, i will have to take it out of the water. ill check back with you guys after sunday when i have time to pull it.\
thaNKS ALOT . will check that first
abearroyo76
for what its worth it goes into drive and starts to move slowly but doesnt get full power to the prop
could be a variety of things from spun prop hub to slipping cone clutches
abearroyo76
thanks i have a feeling i put that old prop under to much stress and decided to go out after 26 years... it is the original one and again for its worth when i got it one blade was pretty beat up..
Ayuh,... So try a different prop on it, before ya pull the boat...
