No Power trim & tilt for 1972 65 hp Johnson
fm50ford
I have a 1972 Johnson 65 HP. I guess there were no Power Tilt and Trim for these motors. I know there are aftermarket ones. but I read about an old style tilt and trim that was aftermarket on one of these boat sites. can't remember which site. Memory is not what it used to be. Does anyone know anything about these old T&T. Would one fit my motor. Who made them and what were they called. Where could I find one
Thanks Great site appreciate the help
boobie
Re: No Power trim & tilt for 1972 65 hp Johnson
Have you looked into CMC Marine.com ??
fm50ford
Hi boobie
Not yet I know there are new aftermarket ones. I am trying to find information on the older one maybe from the 60's I believe. I just can't remember what site I saw it on.
Thanks
Fred
Power tilt was available from factory back then.----Trim and tilt was first offered for the 73 models including the 65 HP long shaft.---------If you can find a good used one you might be able to fit one on a 72 model.----Note , this would depend on how much time you have to fit one.-Results may vary.
fm50ford
Thanks Racerone.
I have been looking for a 73 but from what I have been told at several boat junk yards and a dealer The 73 is totally different. Anyway I haven't found a 73 so I could try to modify it.
Thanks for responding.
They are somewhat rare.----A lot depends on your locale too.----------In some areas the dealer may have sold lots with trim / tilt and other areas they are rare.-------------These motors are long gone in saltwater areas too.
boobie
The '73 won't work on your '72 as the mounting brackets on the transom were different between the years.
fm50ford
Thanks boobie That is what I have been told
emdsapmgr
Also, the 73 and later swivel bracket has holes drilled in it to accept the lift bracket (for the trim pistons.)
boobie
Best bet would still be after market if you want trim. You might find a tilt only unit someplace.
fm50ford
Thanks everyone for all the information
