flatsprowler
- Joined
- Jan 7, 2008
- 6
I have a 2003 F115, its been running horrible under a load. When I have it in nuetral or idle it runs fine and will even rev up to the 45-5000 rpms in nuetral.
If I try to get on plane it just won't run under a load. I have tried running it off an external gas tank, still the same problem. The engine was recently serviced, new plugs, oil change, new impeller, gear oil, injectors cleaned, etc. It ran for about an hour fine when I got it out of the shop but went right back to the same- won't run under a load. I checked to make sure all the plugs were firing and they are. gas is from an external tank. I'm at a loss.
Any suggestions? I have heard that these are symptoms displayed when a power pack goes bad. I don't guess its the fuel pump or injectors if it will rev up in nuetral. I'm scratching my head here.
