My 83 150hp Mercury outboard 2-stroke is about to find its self under water, I have replaced the stator,new plugs,set timing (Which did make it idle alot smoother) I rebuilt the carbs with new gaskets and needle valves, cleaned tank addeds fresh fuel and oil 50:1, compression is around 100 and all are within 5 of that. The problem is that at home hooked to the muffs it runs fine sounds good but when it gets in the water and i give it gas it falls on its face tonight it did ok a couple times when i had it in reverse but it went back to falling on its face any advice would be grate i want this boat on the water soon. Yall have been alot of help thank you
