Had my boat with '86 Yamaha 150 out for the first time in over 90 days this past Holiday weekend. Started fine (always keep filed with treated gas).Warmed up for a while then revved the engine to 2500 RPM or so using the fast idle lever. Revved fine, ran smooth all through the RPM range.
Opened the throttle to bring the boat up on plane and the engine began to immediately "sputter". No power. Max RPM about 1500 but runs really rough and will not even come close to ring the boat up on plane. Shift in to neutral and the engine runs fine even at higher RPM, but once again once in gear and there is a load on the engine it really runs terrible with absolutely no power.
Any suggestion regarding diagonostics or repair sincerely appreciated.
