I have a 1971 Mercury 800 thunderbolt 4 cylinder outboard I am working on.
The problem: Will idle and increase in RPMS in neutral, bogs down and will not go over 5 mph in gear.
What I have done so far: New key switch, Wiring harness, CDI switchbox, coil, carbs removed and cleaned, high altitude jets,plugs,new floats. Compression: 125,125,130,120.
when I began the repairs I found vacuum hose from the bottom cylinder to the carb disconnected. Reconnecting did not make any change to lack of power. The boat did set for 7 years prior to me working on it. Different fuel tank and fuel. Have been running Johnson 7.5 horse on same fuel tank with no issues. I did bring the boat to a repairmen who after 300 dollars said it would have more power, but would need a distributor. Ohh he had said he cleaned the carbs, which obviously had not been a thorough job. When I pulled the carbs after, I found sludge in the filter above the bottom float and the float was cracked.
I have money invested and would love to get her running well.
Any help, much appreciated
