hi guys, I have a 1983 200 and have no power upon accelaration.Motor starts fine and when I go to accel it bogs down.I had 2 bad coils and changed them, rebuilt the 2 fuel pumps, I rebuilt the carbs this summer and was running better than ever I brought the boat home from RI and set out to go black fishing and the motor started acting up. could the power packs break down at a higher rpm? Before I take the carbs off could I check the power packs with a ohlm meter (the book calls out a neon tester)also the bock calls out to use a cd volt meter on the negetive scale to test the voltage can I use a digital style meter to do this test?Any help at this time would be helpful.Thanks Mike p.s. I susspect the carbs might need to be to be cleaned out and I used a ethanol friendly rebuild kit and maybe they got clogged up or something
