Tried to start a 56 johnson 30hp today after it sat for 1+ yrs. It has spark and 80+ compression in each cylinder. The fuel bowl was empty until I hooked up the pressure tank and pushed the button a few times. I saw the bowl fill up as I pressed the button on the tank. When I tried to start it there was some back fireing through the exhaust but no start. It doesn't seem to be getting any gas. I did pull the spark plugs and drop some fuel in each hole and put the plugs back in and hit the starter but no start. After 20 min. or so of this should I hear pressure escape when I loosen the filler cap on the pressure tank? It's a 6gal tank and I only put 1gal of gas and oil mix in it.Thanks for any help!
