Hi all,
I have a 1974 Sterncraft (tri hull). It is an 1150 mercury outboard motor, inline 6 cyl, 115 HP.
I have multiple things I'm trying to figure out before getting it out on the water this year, but the first one I'm concentrating on is getting reverse to work.
1. If I shift it into fully into forward the throttle control is at a 90 degree angle from neutral. If I pull the control back to reverse it only goes back abou 25 degrees and does not engage in gear.
2. While the control is pulled back in reverse, the prop spins both ways (as if it's still in neutral.
In reading through all of the relevant posts, it sounds like I have to adjust the shift cable. However, I don't really understand the directions as I am not just a newbie to boats, but am also a newbie to anything mechanical. Meaning, I have no idea how to interpret the directions I have been reading.
I posted some pics below and am hoping you can walk me through how to adjust this. The top cable is what I am assuming is the throttle cable. The bottom is the shift cable. I can pull the clamp off that holds both of them (first pic), but have no idea how to get to/adjust the shift cable from there.
Again, I'm a total newb. any assistance would be greatly appreciated.
Corey
Corey
