Re: no reverse or neutral after water pump repair
Are you running the motor, or are you trying to shift it without it running? The hydro-electric shift system will always be in forward gear when not running because the hydraulic pump is not turning. It takes hydraulic pressure to shift into neutral or reverse.
Now, if you are saying it won't shift when it is running, that's different. It takes electricity at the wires and hydraulic pressure. No electricity could be wiring or a bad shift switch. No pressure could be no oil in the gearcase. Or dirt, water and crud in the oil.
