no reverse
dtskidoo
1977 johnson 70 hp. lots of miles on it any ideas why reverse would be gone still works fine in forward.
tashasdaddy
Re: no reverse
can you disconnect the cable at the motor, and shift it manually? if you can then you have a bad cable, or cable adjustment. what does it do when you shift to reverse?
dtskidoo
Re: no reverse
yes idisconected cable at motor still cnn,t shift when trying to shift with lever grinds like bottom end is going to blow up
tashasdaddy
Re: no reverse
sounds like the clutch dog is bad. cause usually by easing into gear, rather than a quick deliberate shift.
