Working on a buddys 1988 85 hp force,there is no spark on #1 cyl. Have tested coil,stator checks out,triggers check out, have narrowed it down to 1st powerpak. i want to tie into the 2nd half of the 2nd powerpak,,I am told that this is done quite frequently. My question is,what is the best way to do this,,,I assume just transferring wires on terminal block from #1 trigger,to where wires would be for a 4 cylinder on terminal block would be a start,but not sure where to go from there. Not sure how the stator wires tie into the system from there.
