No spark 1976 f150 6cyl
Newportme
This is my plow truck she will turn over but no spark I am not mechanically gifted but can check the obvious. Can someone point me the right direction?
Bob_VT
Re: No spark 1976 f150 6cyl
Coil wire in tight? What about the other two leads on top of the coil. I would start removing wires... sand them off and re-install them one at a time. If all else fails the module on the fender wall may be bad. They do go without warning.<br /><br />My plow truck is a 78 Ford and I understand your frustration.
bandit86
Banned
check for 12V at the coil. Check to see if the rotor underneath the cap turns.
Newportme
Thanks guys for the quick response I'll check both tonight...you never know when it will snow next
Newportme
Thanks guys<br /><br /> Ended up being the ignition switch 26 bucks at napa Plow on and merry christmas
