103Control
- Joined
- Jul 8, 2006
- 12
Hello,
Well after my 22' 1988 Boston Whaler Temptation with a Mercruiser 454 BBC
330 hp Carburated , generation 4 , ThunderBolt ignition had just died out in the harbor, I pulled it out and I am working on it in the driveway.
I seem to have lost spark, when I push the throttle I do see gas squirting in the carb and the next thing I did was check for spark. nothing,
I used a volt - ohm - meter and it looked like the 12 volt feed to the coil was shorted so I took the feed conductors of the two terminals and brought a direct feed to the coil and it seemed to have a heavy load or a short so I went out and bought a new coil and tried that.
I hooked up the new coil all different ways with and without the parallel feed going to the Thunderbolt ignition box mounted on the manifold and still no spark
I pulled the distributor cap which was all new this summer and new plugs , wires' , rotor etc. and it all looks good to me.
SO I guess my next thing to replace is the "Thunder bolt Ignition IV" Box,
There does not seem like there is much else? BUT I figured I'ld ask here first to see if there is a way to test that box or even run the engine with out it?
