No spark 1997 johnson 175
mr gibbs2
Hello pickup up a newer motor for my boat ran good when I Looked at it good compression ran well started well . Came back pickup motor mounted it on stand. Has system check ,no spark removed harness plug (6) wire purple one, left the other,jump start with remote start switch .now I have spark ,so it must be from the plug back possible the key switch.Is there anyway to test the switch?,are the pols the same as the older red plug harness .it also seams that if it wiggle the key the tach moves.any ideas?thanks
Bosunsmate
Re: No spark 1997 johnson 175
Yep, you can test that there is no continuity to ground on the kill circuit when key is on, sounds like thats whats happening.
Check your safety lanyard line switch if you have one too, they often ground out when they shouldnt.
Im not sure which connector hole is the kill circuit, you can see if yours matches with the diagram on here
continuousWave: Whaler: Reference: Ignition Switch
mr gibbs2
Going to try to test it the kill switch is in the key switch,I like the old way ,may be needs a new switch
mr gibbs2
Had spark with new key switch ,then none only have spark when harness plug is disconnected , does the harness have to be grounded? Or may be a bad tach. . Going to take a closer look at harness . I'm at wits end and help
Bosunsmate
Check for shorts too ground on kill circuit with plug disconnected. Run a whole new kill wire back to motor if needs be
boobie
The harness may have a short to ground on the black/yellow wire in the harness.
