Hi, i have just changed my plugs, cap, rotor, and the bit inside the cap with the red and green stripy wires. I was getting a spark 2 days ago when I grounded a plug and turned the engine over (thunderbolt ignition). Then the ignition fuse blew (15 amp), traced the fault to the bi metal choke on the carb so unplugged the purple wire and the fuse stayed ok and the key worked again. Its hot here (37 deg right now) so I figgure no need for the choke I think. Anyway, no spark at all now, took the coil lead off the distributor and put a spark plug in it and grounded it and turned over the engine but no spark. Noticed there is a purple wire on the coil, is that my problem, some link to the choke pruple wire?
All advice welcome, I am a bit of a DIYer but have a small amount of common sense and want to get my boat going before my wife really gets the hump!
